INPUT only goes up to 2000
Postby Fahim » Wed 4. Aug 2021, 23:20
I have a problem in the INPUT section;
I can only get value up to 1.0 for longitudal, laterial & vertical . Most of the time they are 0.5
If I tick the box "unify values 21-40 start at"
Then I can only get values on the input up to 2000 and no more!
This is the case for both GTR2 and Live For Speed.
The extractor and the convertor seems to work fine together using the plugins provided for both games.
Please help.
Fahim
Re: INPUT only goes up to 2000
Postby sirnoname » Thu 5. Aug 2021, 12:27
Are 2000 positions for your Simulator too less?
Postby Fahim » Thu 5. Aug 2021, 13:25
It appears so. The linear actuator (with string potentiometer - feedback) keeps staying in the middle hardly moving.
Is there anyway to increase input values?
Fahim
Postby sirnoname » Thu 5. Aug 2021, 19:06
You can multiply. But in general you should test for other setup problems. On my side I have big values.
Try the registry clear tool
