Version 3.0.3.0 - Pololu plugin not showing  Topic is solved solved with post #23492
Postby mreiner » Wed 1. May 2019, 09:37
Just realized that there's an updated Version 3.0.3.0
After upgrading, the Pololu Plugin is not working, it's not even listed under the plugins.
I copied the plugin file from the previous version, and it's working.
So it seems there is some kind of problem with the new build of the plugins.
martin
mreiner
Images: 22
Been thanked: 15 times
