by profphil » Sat 13. Oct 2018, 11:18
Hello,
has anybody the same problem as i have, since yesterday evening the converter doesnt work anymore.
The erroe code is Error TCP 4449 listen. Any ideas?
profphil
- Has thanked: 0 time
- Been thanked: 0 time
by profphil » Sat 13. Oct 2018, 16:24
After hours i Found the solution, its an overnight update form Bullguard ( some firewall settings changed ), turning of the firewall on the Converter laptop solved the problem.
profphil
by marwon » Sun 22. Nov 2020, 19:59
My converter does not work any more. first it was the extractor, now the converter
marwon
by sirnoname » Sun 22. Nov 2020, 21:08
There is a x-sim registry cleaner to start over again.
- Site Admin
- Images: 45
- Has thanked: 35 times
- Been thanked: 129 times
