Anyone used DELTA PLC to communicate with PC?  Topic is solved solved with post #19305
Postby emrekonak » Wed 27. Apr 2016, 20:52
Hi all,
I want to move a simple plane cockpit via 2 axis.
I have Delta PLC and i can drive stepper motors.
but im not experienced about communication protocols.
Is there anyone used PLC to communicate with converter?
If not, i plan to use arduino to communicate (because comm prog is available) then i connect it to PLC.
Thank you for any advice in advance
Emre
emrekonak
Re: Anyone used DELTA PLC to communicate with PC?  Topic is solved
Postby sirnoname » Wed 27. Apr 2016, 21:50
For sure not. A DIY community must make it available for all members. That is where a arduino is the best.
However, there is a universal serial output (USO) where you can send any format with a type of RS232 or over network.
http://www.x-sim.de/manual/uso.html
Postby emrekonak » Wed 27. Apr 2016, 22:00
Thank you very much for your reply.
I love arduino as well, so i will be using Arduino and share here what i did.
Best wishes!
E.
sirnoname wrote:For sure not. A DIY community must make it available for all members. That is where a arduino is the best.
emrekonak
