blocking unused engines converter
Postby larux » Wed 23. Mar 2016, 19:15
Hello friends of This beautiful community. My question is the following.
There is Possibility to add a function to your firmware pressing a button 2014 That key or switch position Both engines are centered and fixed?
And then a q When the game starts I change the key position and continuous simulation operation. Independent if the converter is open
Already I was using the HOLD option of the converter but does not serve me.
Greetings and thanks to all !!!!
Español:
Hola amigos de esta hermosa comunidad. Mi pregunta es la siguiente.
Queria saber si habia posiblidad de que le agreguemos una funcion al firmware 2014 de sirnoname que consista en agregar una llave o tecla que al ponerla en una posición los motores se centren solos y al cambiar de posición se reanude el movimiento de los motores? Es decir activas la llave o tecla, le mandas una señal a la arduino e inmediatamente el arduino sabe que tiene q ignorar todo y solo centrar los motores (independientemente que este abierto el converter o no)
Saludos y gracias a todos !!!!
larux
Re: blocking unused engines converter
Postby sirnoname » Wed 23. Mar 2016, 19:23
Hello larux,
what is your firmware 2014?
It is possible to add in math setup a trigger plugin with a joystick button and set all to zero. This math plugin must be on the last possible line. A kill switch.
The zero should be used for center.
Postby larux » Thu 24. Mar 2016, 17:31
sirnoname Hello, thank you for your prompt response.
My problem is that I have no knowledge of that subject :(
Applied Electronics only.
It could be more explicit?
This is the firmware that use Excerpted from "simulator at your fingertips" http://simulador-kaelh.blogspot.com.ar/
FIRMWARE-SIRNONAME-2014-FUSION ARDUINO UNO (this almost the last)
From already thank you very much!!
larux
Postby sirnoname » Thu 24. Mar 2016, 19:12
Ok, but this firmware is part of this developer.
Do you search for a change to the arduino firmware or a setup for X-Sim for a center / kill switch with joystick?
Postby larux » Thu 24. Mar 2016, 21:38
if I seek a change in the arduino to add centering engines with a physical key that will send a signal to any pin arduino (eg high state centered engines, and engines operating low state)
This is possible?
larux
Postby sirnoname » Fri 25. Mar 2016, 01:16
But why? A PID controller should do PID work and not key polling. Changing the firmware is learning how a arduino works and how you can program it.
There is more help in a arduino forum.
You can center/start with X-Sim and a key if you zero the output on a key press.
Postby larux » Sat 26. Mar 2016, 02:19
Ok I understand, I will find some programmer friend to help me with this issue because the plugin do not know how :(.
Anyway, thank you very much for the info :)
larux
Postby larux » Mon 28. Mar 2016, 05:27
Where is trigger plugin? and how to add joystick button and set all to zero.?
I have spent a long time researching but almost nothing on this subject
Greetings and thank you very much
larux
Postby sirnoname » Mon 28. Mar 2016, 11:41
Math setup left side. Use online manual to find out what it will do.
