K8055 hydraulics configuration problem
Postby kappacina » Mon 15. Feb 2016, 12:06
Hello to all you guys and sorry for my english. I kindly ask you if anyone can help me in this configuration. I managed to install everything and the sim works well almost ... almost, because there's something I just do not understand. My previous configuration had a piston which managed the axis x and one y (type rock'n'ride) and worked fine. Now I am redoing platform I thought to put the Pistons back type simforce gt. I configured everything and pistons work well but I can not understand why it is using the value 25 (lateral force) and 26 (vertical force) the simulator after giving me the effect was not much in the center alone as he did with the old configuration, ..se want to get it back in the center I have to steer the other side or if it is down or right or sx.In practice does not follow me telemetry but seems to react only to the inputs of steering wheel.I made the manual calibration to take maximun - minumun and center for each actuator. Not understand if I have to add some value to the configuration to make it back to the central in automatic mode follow the track.ecxatly for pitch.. from the surge at the start and then he stands there and if you brake me back in the center but not in later :-(. I miss you a value in configuration .Any idea? thanks a lot and good day to all the forum!
kappacina
