transforming yaw from lfs  Topic is solved solved with post #18883
Postby asafxsim » Fri 25. Sep 2015, 15:55
Hello,
I get the yaw param from the lfs plugin but not the angular momentum even though the outsim window shows it.
The problem is that the yaw received is an angle,
And for the 6dof platform I think I should use the angular momentum ?
If so, how can i get this param ?
Asaf
asafxsim
Re: transforming yaw from lfs
Postby sirnoname » Fri 25. Sep 2015, 18:52
Simulators simulate the forces, not the position. roll and pitch do have forces because to earth middle.
Postby asafxsim » Sat 26. Sep 2015, 13:33
Thanks a lot for the response :)
asafxsim
Re: transforming yaw from lfs  Topic is solved
Postby kanki » Fri 26. Feb 2016, 14:57
It did not take the angular velocity in the X-SIM, calculated by the external.
To send the angle to arduino, and convert the angle to the angular velocity in the arduino.
kanki
