Start button how switch functions in arduino
Postby AlexNester » Sat 12. Sep 2015, 15:27
hi all
I have a problem with functions start() and stop()
I need when button 'Start' work function start(), and when button STOP - function stop()
it's my code
Code: Select all
void SerialWorker()
  if (Serial.available()>4)
      for (q=0; q<5; q++){bufferArray[q] = Serial.read();}
       if(bufferArray[0] == 'S'){ start();}
       else { stop;} ///or if(bufferArray[0] != 'S'){ stop();}
this code not work correctly
after start It works as I have, but problems after stop. Not switch on function stop() or switch after RESET arduino.
How FIX this problem?
I've tried in USO send datapacket at simulatorstop but convertor not send my data after stop.
AlexNester
Re: Start button how switch functions in arduino
Postby sirnoname » Sat 12. Sep 2015, 16:55
Send me a sample rn2 file to verify your stop setup ind converter.
Postby AlexNester » Sat 12. Sep 2015, 17:57
I using USO
Here he is
USO2.rar
USO
(1.32 KiB) Downloaded 826 times
AlexNester
