New actuators scn5 not scan by converter
Postby lyspatriote » Sun 6. Sep 2015, 06:04
After a problem with a pc a ad to swich actuators, from one simulator to the other, but with one pc it dosent reconnise the actuator when it scan for devise. On the connector FT232R USB UART i dont see light like when someting going on. i know those work i have try with my laptop no proplem(window 8) , i try un-instal the connector, re-instal x-sim, the pc see the connector correctely but it dosent exist for x-sim, on one pc (windows7) i guess there a memory someware that refer to other actuators then those, but on the other pc, and my laptop it work. What should i do, i consider upgrading to windows 10 to fix it but not sure all my devise will work.
what sould i do ?
lyspatriote
Re: New actuators scn5 not scan by converter
Postby lyspatriote » Sun 6. Sep 2015, 17:27
he when it plug my usb converter i got this
LPT1 digital...
i sould have scn5 000000255 position
how can i fit this
lyspatriote
Postby lyspatriote » Sun 6. Sep 2015, 17:32
and my pc see my connector
lyspatriote
Postby sirnoname » Sun 6. Sep 2015, 18:31
Use debug mode to find the exact detection problem step by step.
FTDI need sometimes advance settings: printer mode and zero timing delay.
And: what is your actuator??
Postby lyspatriote » Sun 6. Sep 2015, 20:07
ok will try that , not sure what is debug mode.
My actuators are 150mm scn5
thanks a lot
lyspatriote
Postby lyspatriote » Sun 6. Sep 2015, 20:15
sirnoname wrote:Use debug mode to find the exact detection problem step by step.
debug mode where? in x-sim?
what is FTDI where do i put it in printer mode 0 timing delay?
sorry
thanks
lyspatriote
Postby lyspatriote » Sun 6. Sep 2015, 21:05
ok i got that FTDI is the connector
but in advance setting i got this
if i un-clic load vcp
i got choise from 1 to 3600
lyspatriote
Postby sirnoname » Mon 7. Sep 2015, 00:27
You must read the SCN5 instruction and manual before you continue!
Project gallery -> controller and drivers -> SCN5 software thread
Postby lyspatriote » Mon 7. Sep 2015, 04:19
ok i read the section you refer to
2 weird ting from your explication about the
Registry editor
in computer KKEY Local machine/software i did not find x-sim find it in Hkey current user
and the rest of the road is not there so i cannot acces the debug mode
but upgradin to window 10 would solve my problem right?
thanks again for what you do
lyspatriote
Postby sirnoname » Mon 7. Sep 2015, 18:18
64 bit OS -> wow6432node !!
Please, please read the whole thread!
And check the driver what is the hint before you read debug mode. You need that dialog.
