Signal from the Converter Start button
Postby mereni » Mon 6. Apr 2015, 00:00
Hi
Is there a simple way to activate a switch or a led or whatever when the "Start" button of the Converter is pressed ? When inactive, my rig is held in place by a kind of hoist (see picture), which I regularly forget to retract when I start the converter (you can imagine the disaster for the poor actuators...). The ideal solution would be for me to automate this retraction, based on a signal or status received from the Converter...
3744
Thanks in advance for any help or suggestion
mereni
Images: 21
Re: Signal from the Converter Start button
Postby sirnoname » Mon 6. Apr 2015, 10:44
Many. One way may be using the synaptix and set on stop to zero and all other to 1. Then use center on stop in program setup.
Postby mereni » Mon 6. Apr 2015, 16:26
Thank you for your prompt answer, Sirnoname
I must admit I do not yet totally understand all of your answer, but I am actively digging into it!
I suppose I have to start with the hardware segment :
Am I right in assuming that :
- if I want for example to drive à 5V relay, all I have to do is plug the relay into a Velleman or into pins 2 and 3 of a cheap Arduino Uno card (any preference ?), which I will then connect to any USB port ?
- an then a new interface will appear in the list of "found interfaces" of the Interface settings screen, without any programming of theinterface card (??) ?
- "center on stop in program setup" : did I understand well, this is here :
3756
- "set on stop to zero and all other to 1" : did I understand well, is this the right page to do this :
3757
mereni
Images: 21
