Problem: motors don't stop at 0% or 100%
Postby AndiMe » Fri 12. Sep 2014, 18:14
Hey guys
I'm using the converter with a Velleman Module. I inserted a sequence with a dynamic value. This value goes to the Velleman dynamic output and changes the speed of my motors. The problem is now: I tried to make a new profile for no limits rollercoaster but the motors will not stop at the point of 0% or 100% of the reference input. The value of "Test axis result" is 0% or 100% but my motors are still turning. Does anyone have an idea what this could be?
Thanks a lot and greetings
Andi
AndiMe
Images: 19
Re: Problem: motors don't stop at 0% or 100%
Postby AndiMe » Sat 13. Sep 2014, 14:51
Hello everyone
I found out the following problem and maybe someone knows why that occures. In the picture you see 3 screenshots:
3160
1) As you can see, my simulator is in a horizontal position of more or less 50%
2) The calibration offset is 0
3) Why is the output value so high? Also the value from the RollerCoaster software is more or less "centered" means, there is no tilt motion because standing at the start place. But the output value is increadible hight...
Could anyone help me?
Thanks a lot and have a nice weekend
Andi
AndiMe
Images: 19
