Kangaroo x2 Plugin
Kangaroo x2 Plugin
Postby telfel » Wed 28. May 2014, 19:18
Hi Sir
Kangaroo set at Address 128, 9600 baud, Channel named 1, & 2, are recognised in the interface plugin window,
If I change any one of the parameters then the Kangaroo is not recognised.
For 6 dof, I would like to use 3 Kangaroo's @ 115200 baud, Address 128 ch1, ch2, / 129 ch3, ch4, / 130 ch5, ch6.
regards Terry
telfel
Images: 54
Been thanked: 9 times
