K8055N keine Ausgänge
Postby Jens » Sun 9. Feb 2014, 16:47
I am absolutely new here and would like me a Racing Seat with 2 Bewegachsen (for brake / gas power and for the sides force simulation) The whole thing should run on RBR. Have me with the program already set several days apart and I'm already getting few steps further. Unfortunately, I can not do it to get an output signal on the interface board it. Manual can I set inputs and outputs. Thus, the Board seems to work.
I get data from the game (positive and negative values ​​for each force direction)
My guess is an error in the setting in the Output Setup. For many settings in the program I can take anything and have already experimented back and forth. Unfortunately, without success.
What can I have done wrong?
To me it seems but also as if the values ​​obtained from the game are not converted to an output value. But where can I see this?
Jens
Re: K8055N keine Ausgänge
Postby sirnoname » Mon 10. Feb 2014, 02:18
