Checksum and USO
Checksum and USO
Postby Wanegain » Mon 6. Jan 2014, 23:43
Hi all,
I am writing a code for an Arduino Uno wich will drive 4 motors (maybe 6 later) using 2 sabertooth in serial mode.
I would like understand what I need to write in my "Datapacket with axis informations" shield :
- I chose 8 bit resolution and dezimal output.
- I named my axis with A, B, C and D
If I want a checksum only for data from axis (I don't need to verify the A, B, C and D characters because I check them in my code to get the data), is this correct : A~a01~c01~B~a02~c01~C~a03~c01~D~a04~c01~ ??
Currently I didn't test it because I didn't finish my code. But please tell me if something wrong !
Thank you !
Wanegain
Re: Checksum and USO
Postby sirnoname » Tue 7. Jan 2014, 02:12
xor of all bytes
Postby Wanegain » Tue 7. Jan 2014, 11:24
Thank you for your answer, but this is what I need to do in my code, isn't it ?
I want to know if A~a01~c01~ will make a XOR checksum of only a01 ?
And if I well understood, A~a01~c02~ will make a XOR checksum of A and a01, right ?
Just to be sure...
Wanegain
Postby Wanegain » Tue 7. Jan 2014, 15:30
If I chose 16 bit resolution, do I need to add +1 to the ~c0x~ (e.g. A~a01~~c03~) ?
Do I have to put ~~ between a01 and c02 ?
Wanegain
Postby sirnoname » Wed 8. Jan 2014, 02:04
good question, I think yes.
Use the free serial port monitor, it is good to sniff the datas while connected to a device.
Postby Wanegain » Wed 8. Jan 2014, 15:41
This is really good idea !
Thanks again for your answer.
I will try it.
Wanegain
