Converter setup for 3dof (Amc + Arduino)
Postby RafBR » Tue 20. Aug 2013, 02:21
I am about to set this 3dof up but dont know how exactly :)
I have my old AMC 1.5 and now one Arduino Uno to use together. My two DSMHB's are wonking fine aswell.
Well I am not sure what to do on the USO setup :?
Please I apreciate any clues.
By the way I dont have the simulator to show you. I did not made it yet. Im starting with the electronics because it is what I am afraid of :o
My regards,
Rafael.
RafBR
Images: 24
Re: Converter setup for 3dof (Amc + Arduino)
Postby yokoyoko » Tue 20. Aug 2013, 12:18
I would assign the arduino via the output section after you set it up in the interface section. The AMC 1.5 as you know with the USO settings.
Postby RafBR » Tue 20. Aug 2013, 17:24
Yoko,
The output section does have Synaptrix and USO... can I assume you mean the Synaptrix for the Arduino?
Sorry if this is silly question :)
Also I noticed (USO setup) that we can "Enter available comport" and add entry to list.
Maybe to use only USO for both AMC and Arduino is possible?
Well thanks for you attention anyway!
Rafael.
RafBR
Images: 24
