two k8055 walleman...xsim issue...Help
Postby robcoll » Thu 25. Jul 2013, 02:17
two k8055 walleman...I can switch them around Nr 0 Nr 1 xsim reads both but only send to one...
it sees both card at the profiler...press START AND ONLY ONE CARD WILL OUTPUT the other does not output...
and will freeze up....:( if I run one card at the time will work...k8055 demo runs both no problems..x-sim and k8055d.dll updated 5.0.0.0...installed in syswow and system 32 (My system is a win 7 (64)...Im using the anolge outputs on both for a 3dof...Help..
robcoll
Re: two k8055 walleman...xsim issue...Help
Postby sirnoname » Thu 25. Jul 2013, 09:23
What is your synaptrix artificial time break?
By the way, velleman, not walle.
Postby robcoll » Thu 25. Jul 2013, 15:04
sirnoname wrote:What is your synaptrix artificial time break?
Thanks sirnoname...normal priority----sysnaptrix artificial time break is set to 10...
robcoll
Postby sirnoname » Thu 25. Jul 2013, 15:26
set it higher ... begin with 50 and go down.
Postby robcoll » Thu 25. Jul 2013, 16:09
sirnoname wrote:set it higher ... begin with 50 and go down.
Thanks...I will try at soon I get home tonight..
---What exactly synaptrix artificial time breaks does..? not really familiar whit it.. :?:
robcoll
Postby robcoll » Thu 25. Jul 2013, 16:19
This maybe answer that question...
"The artificial breaK setting is a number that represents the duration of a pause.
This pause allows the PC to perform other tasks for the duration of the pause."
robcoll
Postby robcoll » Thu 25. Jul 2013, 16:35
Increasing this values will give the program extra time to work, decreasing will give other tasks more CPU time.
The artificial time will be a break every control round to free CPU load if not needed...
robcoll
Postby robcoll » Fri 26. Jul 2013, 15:58
Thanks again sirnoname... ok..here is the status of my finding...started at 50 and went down to 5 with not avail...but if the pc is isolated CPU 1-7(dedicating one core for the x-sim)..that is how it was set from the beginning when I have only one card ,it does not send data out (the output led on the second k8055 card don't lit on ...but if i reset it to normal means CPU 0-7..(not core isolated).it does come on and start sending...run it for couple hours while flying a plane and never freeze up or disconnect...now my setting ares 10 and 20..
Question: why my PC wants to do it backward with isolation of the Core...?
my system is : ASUS I-7core 3.5hz 16gb ram 2Tr hard drive two-560 NVIDIA graphics card 3 ASUS monitor yoke and pedals..
robcoll
Postby sirnoname » Fri 26. Jul 2013, 19:07
Standard is not isolated.
If you load a 3rd party profiles you may switch it.
