k8055..sabertooth..wipers
Postby Babykuni » Wed 20. Jun 2012, 01:41
I keep getting errors and the k8055 is not reconised by the x-sim converter.I am using x-sim 3.0.0.4
there is no IP address or anything in all oupput of found devices other than base shaker and i don't know where that came from.
Also when i hook the usb cable into the k8055 and computer i get this windows message
k8055 and sabertooth works with the k8055 demo but i just can't get past this point of the programming.
Thanks Bruce
Babykuni
Re: k8055..sabertooth..wipers
Postby sirnoname » Wed 20. Jun 2012, 09:08
If there is no IP address goto the advanced lan setup and move your real LAN adapter to the first place.
In your second picture you are using the velleman demo and X-Sim at the same time.
Postby kevin123 » Wed 20. Jun 2012, 17:53
In fact .... you made the same mistake I did at the beginning I used the Velleman K8055 demo then I opened x-sim converter but to me said interface dll not found ......
@ SirNoName that eye that you have :D .... congratulations
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Postby Babykuni » Sat 23. Jun 2012, 11:34
Well played around abit.The laptop i have is a Toshiba I7 with windows 7 (gaming laptop) and still having trouble.So swapped everything to the wifes computer (vista).Loaded game and x-sim 3 to it and everything worked fine.So laptop no good.Will build myself another computer and start again.Thanks for the replies to my questions.
Babykuni
