Com Port Errors, JRK, XSim3, PC?
Re: Com Port Errors, JRK, XSim3, PC?
Postby Erwan960 » Tue 16. Jul 2013, 23:12
Hi !
I just finished my cockpit prototype based on Zyt 90-155 motors driven by 12v12 jrk. Everything works fine under jrk configuration utility (speed, pid, min, max...).
But when I launch X-Sim, I get that : "error opening USO comport..." for my 2 jrk (com4 and com6).
I am using usb cable from pololu. I have just ordered new one on amazon. Hope it will help !
Erwan960
Postby yokoyoko » Tue 16. Jul 2013, 23:25
Hi, is there a reason why you are using uso commands for the jrk's?
I would recommend you to use the interface plugin for the jrk's - as you can use 12bit of resolution insted of 8bit (with uso).
setup like in this video - you have toignore the part from the beginning up to 1:30min...
make sure all the uso entries for all jrk's are removed!!!
if you dont have created axis in the math section before - x-simwill ask you what of your outputs should be used for a new axis. otherwise refer to the video and assign them "manual".
Hope this helps! Your pololu usb cables should be fine - no need for other one.
Postby Erwan960 » Wed 17. Jul 2013, 13:30
It seems that I mixed information from different subjects... Thank you very much for this development.
Now I am able to correctly associate the software (Project CARS) with the dynamic cockpit without error.
https://www.youtube.com/watch?feature=p ... MRFoi7rpt0
Remains to adjust the motor courses and the spring tension at the ball.
Erwan960
