x-sim download  Topic is solved solved with post #25067
Postby Eden » Sun 19. Dec 2021, 00:55
Hello, I have not been able to download the updated version of x-sim from the download section, I have tried several browsers without success, it does not download, what can I do?
Eden
Re: x-sim download
Postby firstcello » Fri 24. Dec 2021, 01:29
same problem here.......waiting for an answer
firstcello
Re: x-sim download
Postby freskito » Wed 19. Jan 2022, 06:42
Same problem....Help !! I cant download, i cant see post #25067
freskito
Re: x-sim download
Postby Dando » Sat 22. Jan 2022, 11:43
Hello!
I managed to work around this download issue by inserting "https://www.x-sim.de/forum/dm_eds/files/xsim/X-Sim_Setup_3.0.3.2_aluminum_23082021.zip" directly into the microsoft edge browser adress field :D
Dando
Re: x-sim download
Postby faizanmazhar00 » Wed 16. Feb 2022, 12:41
firstcello wrote:same problem here.......waiting for an answer
faizanmazhar00
Return to X-Sim Q&A/FAQs
