FSUIPC or input setup "noise" data ?
Postby maurilio » Mon 25. Jan 2016, 03:20
Hello Simers,
I'm trying to make a simple 2 axis (pitch & roll) profile for use with FSX.
Should I use #33 (2F78) for roll(to bank) ?
When connected to Extractor, the Converter input setup list show a ocillating values at #33.
I've donloaded the newer FSUIPC 4949 and not solve it.
Thanks,
Maurilio.
maurilio
Re: FSUIPC or input setup "noise" data ?
Postby Zeus » Thu 9. Jun 2016, 02:25
2F78 is the attitude indicator roll. It normally follows the aircraft roll but if, for example, AI fails, this value will fall over to one side.
For aircraft roll (bank), you should use 057C, but note the units are different (int 2^32 = 360°) and, typically for FSX, the sign is wrong.
Zeus
Return to X-Sim Q&A/FAQs
