Extractor to Convert TCP/UDP Ports  Topic is solved solved with post #17901
Postby BrassEm » Sun 1. Nov 2015, 04:51
G'day,
After many fruitless searches through the manuals and forums I still cannot find which TCP/UDP ports need to be opened to get the Extractor to talk to the Converter over a firewalled network. Would someone please post which ports need to open.
Thanks,
EDIT:
The extractor only establishes network coms with the converter after the "Play Game" button is pressed on the extractor. With both apps running at the same time on the two computers it looked very much like the old blocked port issue.
BrassEm
Images: 66
Return to X-Sim Q&A/FAQs
