Must we launch jrk utility everytime before xsim
Postby boons4 » Sat 14. Jul 2012, 15:28
I guys I am using xsim2 software at the moment and hope to switch to xsim3 soon.
Currently when i launch force sender and start button on my force profiller , the seat mover will not wake up, I have to start up jrk utility and run motor for both axis one time, then go back force sender and profiler and my seat mover will wake up... Is there any problem or some setting I never do?
Is there a way to ensure the seat stop at upright center position when we click the stop button? Some how my weight n cg always cause the seat to tilt to lower left side when I stop the simulator. Thanks
boons4
Re: Must we launch jrk utility everytime before xsim
Postby motiondave » Sun 15. Jul 2012, 01:43
The seat frame will always rest to the back when you stop x-sim. Because the power goes off. Just remember to lean back, when you stop the x-sim program.
Thats weird, why the motors do not start with convertor, I will have a look later at that.
You need to use x-sim 3, we cannot answer x-sim2 related questions here.
Postby motiondave » Sun 15. Jul 2012, 01:56
I just had a thought, it used to do that to me as well on x-sim2 on occasions, but that seems to have stopped using x-sim 3. Maybe the x-sim writer fixed something.
Try setting up using x-sim 3 and see how it goes.
Return to X-Sim Q&A/FAQs
