X-sim and G27 Buttons
Postby kbssa » Tue 6. May 2014, 14:31
Hi all,
Anyone here could say me if there is possibility to send a G27's pressed button through the USO ?
I need that to change the functions of a dashboard that I am building.
Any help will be greatly appreciated.
Bruno
kbssa
Images: 16
Has thanked: 5 times
Re: X-sim and G27 Buttons
Postby adrianovrm » Tue 6. May 2014, 15:11
Hein Bruno,
the brazilian group dont have more posts, there was a great place for information months ago, but letś go ahead, l think
that a is not possible do that, th x-sim is only a output information software. You will have to deal with some software like
ppjoy or vjoy tha emulates inputs, analog one too. ppjoy only works under windows XP. The another way is use an arduino with a generic wheel, with a motor and feeedback device (potentiometer). thereś a project called unojoy and megajoy that converts an arduino into a joystick device that windows recongnize and buttons can be mapped over rfactor,
x-sim is out from this conversation
adrianovrm
Postby sirnoname » Tue 6. May 2014, 15:57
Yes, you can get buttons of your wheel with OBD2 interface and USO.
For OBD2 you can read the front page threads. It is a solution without the need of the converter application for all dashboard builders.
For USO you must add in math setup a G-Force plugin with the joystick button out of the drop down menu and then you have a math axis for USO.
Generally use the OBD2 addon of the extractor for dashboards, manuals in the posts and in the doku section. It is very simple and unified.
Postby kbssa » Tue 6. May 2014, 20:32
sirnoname wrote:Yes, you can get buttons of your wheel with OBD2 interface and USO.
Thank you very much for your support sir !
I think I will use USO cuz I want more information as RPM, speed, gear, lap, fuel, etc...
Is it possible to get all that information with OBD2 ?
kbssa
Images: 16
Postby vicpopo » Tue 6. May 2014, 20:42
Hi kbssa,
You can find the topic here :
http://www.x-sim.de/forum/viewtopic.php?f=40&t=1083&hilit=Obd2+protocol
Hope you can find what you want ! ;)
Postby sirnoname » Tue 6. May 2014, 21:03
yes you can
Speed with higher than 255 is supported also. The values that original OBD2 do not support comes with reserved commands and are usable for apps like tourque or dashboards with arduino or other microcontroller.
Postby kbssa » Wed 7. May 2014, 02:42
vicpopo wrote:Hi kbssa,
Thank you vicpopo !
I found almost everything I needed in the topic and now will start working on my dash :D .
The only thing I have not found is how to get speed higher than 255. I will be thanked if you can point me to right direction.
sirnoname wrote:yes you can
Thank you again sir for your reply !
kbssa
Images: 16
Postby vicpopo » Wed 7. May 2014, 08:24
Hi kbssa,
On the first post the link i gave you above (obd2 thread),you will find an ''edit 29/04/2014" and just below you can download the code and inside the new pid E9 which become the avaibility to display speed up 255km/h.
Return to X-Sim Q&A/FAQs
