connection probs
connection probs
Postby seppel » Sun 21. Jul 2013, 19:51
hi folks,
today i installed the xsim-software for the first time. i got the extr. on my game pc(win7) wich go online with a wifiadapter; the conv. is on my sec. pc (win XP) wich goes also online with an wifi adapter. both pc are in the same network, both firewalls are offline, ping to eachothe work fine.
i try to use for both a cable network connection with static ip, ping is fine but no connection.
my prob is now that there is no connection between the ext. and the conv.
can someone help me with that problem?
regards
seppel
hi leute,
hab heute zum erstem mal die xsim software installiert. mein spielepc(win7) mit dem extr. geht mit nem wlanadapter online und mein 2ter pc (win xp)mit dem converter ebenso. beide sind mit zugewiesenen ip im netzwerk, pingen klappt einwandfrei, beide firewalls sind aus.
hab schon versucht beide mit ner kabelverbindung zu verbinden und das kalppt ebenso ohne stress.
egal was ich mache ich bekomme keine verbindung zwichen den beiden programmen auf den pc´s.
hat jemand ne idee was ich noch probieren könnte??
danke im vorraus
seppel
seppel
Images: 34
Re: connection probs
Postby seppel » Sun 21. Jul 2013, 20:47
ok problem solved, only a beginner mistake :oops:
seppel
Images: 34
Postby sirnoname » Sun 21. Jul 2013, 23:49
No Wifi between extractor and converter !!
Ping has to be 0ms to avoid delays.
Postby seppel » Sat 3. Aug 2013, 19:33
hi folks,
the con. problems between extr. and conv. are solved, I thought so. these day i do the fist testruns on my rig with gtr2.
the first connection with game start are ok and normal but on the track i lost the connection several times. were is the problem and what do i wrong. and yes sirnoname, i got only for internet a wifi, for x sim ext. and con. communication i got
oldschool cabelnetwork.
thx for some ideas.
best regards seppel
seppel
Images: 34
Postby yokoyoko » Sat 3. Aug 2013, 22:01
Hi seppel,
leider kenne ich deinen sim nicht wirklich. Klär uns kurz auf was für motoren du verwendest und aus welchem material die halterung der motoren sowie der rahmen des sim ist.
Falls du wischermotoren verwendest habe ich eine idee woran deine probleme liegen...
Weiterhin kannst du dir via google mal ein comport logging tool besorgen und die connection probleme weiter eingrenzen.
Soweit... gruß yokoyoko
Edit.: beim zweiten lesen glaube ich ich habe dich missverstanden ? Kommen die probleme zw. Extrqctor und converter oder verliert der converter den kontakt zu deinen controllern?
Postby seppel » Sun 4. Aug 2013, 12:43
hi yoko,
danke für deine antwort!
meine sim kannst du hier anschauen viewtopic.php?f=37&t=883
ich verwende 2 scn5er mit nem devantech usb adapter.
die probleme kommen definitiv vom verbindungsverlust zw. extr. und converter. während der testfahrt zeigt das obere rechte symbol "not connected" an, dann wieder die ip usw. ich hab schon lankabel ausgetauscht, kartentreiber neugebügelt das volle programm. ich hab als converterrechner nen kleinen dell mit win xp und nem handelsüblichen netzwerk mit statischer ip.
ich werd ma nach dem logging tool schauen, vielleicht hilft das mir weiter.
seppel
Images: 34
Postby yokoyoko » Sun 4. Aug 2013, 14:22
Ne ich denke das tool wird dir nicht helfen. War auf nem völlig falschen dampfer... dachte du hättest eventp. nen wischer-masse problem was deine controller disconnected.
Lesen hilft halt... hatte da etwas vorschnell gepostet.
Zu deinem eigentl. Problem habe ich spontan keinen lösungsansatz. Wir warten mal was sir sagt.
Postby seppel » Mon 5. Aug 2013, 17:41
hi leute,
ich habe eben mal mein notebook als extractor plattform verwendet um einen fehler meiner netzwerkkarte auf dem dell auszuschließen, aber mit dem notebook hab ich dieselben probleme. ca alle 30 bis 40 sekunden schaltet der extractor ab und ich muss ihn manuel "Starten", dann läuft er wieder für ein paar sekunden dann wieder disco.(also verlust der LAN-Verbindung "Netzwerkabel nicht angeschlossen..."
ist es hilfreich mein profil zu posten oder sonstige einstellungen?
woran könnte das plötzliche abschalten sonst liegen.
schon ma vorab, danke für die hilfe
seppel
seppel
Images: 34
Postby seppel » Thu 8. Aug 2013, 18:03
hi leute
ich habe versucht mein verbindungsproblem einzugrenzen und folgendes probiert:
-verwendung verschiedener lankabel -> gleicher fehler
-verwendung eines switchs -> gleicher fehler
- senden eines dauerhaften ping auf beide rechner-> 0% verlust
habe nochmal für gtr2 ein testprofil mit dem http://www.x-sim.de/documents/X-Sim%20Quick%20Guide.pdf guide erstellt -> gleicher fehler
habe mit dem guide ein testprofil für rfactor und dirt2 erstellt und siehe da -> konstante verbindung, kein abbruch (noch :) )
ich denke das der fehler bei gtr2 liegen muss, vielleicht ein fehlerhaftes plugin oder ne unsaubere instalation.???
1962 das passt?
hat jem ne idee oder ahnung von dem gtr2 plugin??
beste grüße
seppel
seppel
Images: 34
Postby seppel » Fri 9. Aug 2013, 17:17
hi folks,
problem is solved!!
i delete the whole gtr2 game(25gb) and set up an new instalation. after all improtant setting in the game and in the converter i go on trak with no disconnect.
so i´ll work the final steps on my rig.
best regards
seppel
seppel
Images: 34
Return to X-Sim Q&A/FAQs
