2DOF Racing Seat 2x Sabertooth and k8055 Sim
Re: 2DOF Racing Seat 2x Sabertooth and k8055 Sim
Postby warstyl » Mon 29. Oct 2012, 14:55
Hi motiondave ,
Thanks for the update ,I am just doing a backup at the moment once this is done will load windows 7 and see what it does .
Will keep you posted
Thanks again
warstyl
Images: 184
Postby yokoyoko » Mon 29. Oct 2012, 16:16
mhh. Using one Pc for both (extractor and convertor) is the simpliest way. Normally (on win7 - no other os tested here) you just open both programms as administrator. If win ask you to pass the programs through the firewall - you hit "ok" (on first start of the programs).
The extractor recognizes that there is a convertor running on same pc. (normally)
Best regards
yoko
Postby warstyl » Mon 29. Oct 2012, 17:05
Thanks yokoyoko ,will keep you posted once tried
warstyl
Images: 184
Postby motiondave » Tue 30. Oct 2012, 13:42
yokoyoko wrote:Hi,
Best regards
yoko
It works on xp, but you cannot use graphics driver as it is dx11 only.
Postby warstyl » Thu 1. Nov 2012, 13:32
Hi motiondave /yokoyoko,
I have formated my laptop and installed win 7 ultimate .Just to let you know if you go to run and type indxdiag you will see that win7 has dierect x 11 installed .
I still have the same issue .Excuse my ignorance
I think I am overlooking something in the profiles I think .Can you tell me if you run one pc for the xsim converter and extractor and another for the game or do you run them all on one pc.If this is the case (all on one pc ) how would you see what is happening Feed backback values etc. while you are running the game ?
If you are running two pc`s do you network them together or go online to see if there is feedback while you are running the game .Which game profile have you gents been using .I have tried dirt 3 lfs and racedriver grid so far and the basic setup profile.
warstyl
Images: 184
Postby yokoyoko » Thu 1. Nov 2012, 14:38
Excuse my ignorance
No problem - you are welcome.
I made a short low quality video with my phone. I hope this helps more as if I try to explain in a broken language ;-)
Please check if you have this symbol in the right upper corner of the convertor:
If you use two PC:
Or if you use one Pc: "please look the vid - the symbol says "locally running""
here a short video of changing values:
Best regards
yoko
edit:
The extractor always have to run on the same PC like the the Game. For the Convertor you can use also the same PC or another over network or both. You can also run several convertors over network if you want to.
If you are running everything on one PC - is it useful (until everything is setup fine) - to play the game in "windowed mode" to quick switch between Game and Convertor. Otherwise you can use "Alt+Tab" on your Keyboard to switch between aplications.
Postby warstyl » Thu 1. Nov 2012, 15:46
Hi yokoyoko,
Thanks for the very informative explanation,
Iwill go through everything and let you *
warstyl
Images: 184
Postby yokoyoko » Thu 1. Nov 2012, 16:03
If you got teamviewer I can have a look if you want...?
Postby warstyl » Thu 1. Nov 2012, 16:23
Thanks yokoyoko ,I will set it up and let you know when i am ready give me an hour please
warstyl
Images: 184
Postby Battlestar » Thu 1. Nov 2012, 18:34
Hi Warstyl,
I run X-sim3 on one PC running win7. My solution to the problem that you appear to have is to connect a second monitor.
The Exractor and converter are both running on the secondary monitor and the game plays on the primary monitor. No messing about and no difficulties. Hope this helps.
Mike
So Say We All
Battlestar
Return to X-Sim Q&A/FAQs
