what card should i use to move my sims
Postby fork-winged devil » Wed 12. Dec 2018, 23:10
hi all im wanting to know if i can run the ARDUINO card to run my 2deg flight sim im using il2 for gotten battles will this card read the out put code from the sim also i fly black shark on my full size ka50 cockpit sim an will build a 6deg motion base for this at some point
OK iv just check out the site a bit more looks like the card will do those sims, the next thing is i have two 24v dc 3.5 amps EMD wheel chair motors if i use the ARDUINO UNO CARD what H-bridge card should i use what will run these motors or do the H-bridge cards only do 12v dc 2 amps max
another thing i need to find out is if you can adjust the washout at the end points in the software
thanks for any help with this part of my projects
fork-winged devil
Images: 17
Re: what card should i use to move my sims
Postby sirnoname » Fri 14. Dec 2018, 12:11
If you are a newcomer simple buy some more and different versions of boards for your experiments. Maybe china parts. You will brick some. A motor with 3A will make electric noise that is like 6A on PWM load. Do not waste time with under limit designs.
Postby fork-winged devil » Fri 14. Dec 2018, 13:14
i got the arduino mega card today so i should look for to motors 12v and under 2amps this build is for my 2deg cradle flight simulator
fork-winged devil
Images: 17
