Help bass shaker setting
Postby rantalone » Wed 4. Oct 2017, 22:01
Hi everyone, as a title I would like to add basshakers, (already in my possession) to my post. Can anyone tell me how to configure x-sim? Adding the profile settings to effect street, curb, gear change, and maybe traction losses? Thanks to everything for the help, I'm new and this software alone is really difficult
rantalone
Re: Help bass shaker setting
Postby DFKK » Sat 10. Mar 2018, 17:09
Hi Mate! Did you find any solution becouse the settings are difficult for me as well. Cheers!
DFKK
Postby Adik » Sun 11. Mar 2018, 11:56
You need two soundcards!!then create two axis,one for vol and one for freq.you can search it here,there is a pdf file how to.you must click the bassshakerer plug in and there you can test you soundcard.but you need two souncards.
http://www.x-sim.de/forum/download/file.php?id=141
Adik
Postby DFKK » Wed 14. Mar 2018, 14:07
Thank you for the answer! I did read everything what I found. The dedicated soundcard is tested by the plugin so its functional but everytime I start to run the live 4 speed its skips or does not happening anything. Maybe it is not suitable for LFS. I tried every profile what i found but nothing hapening. When i have 2 or more profile it just skips out from the profile or... If i just put one on the list it just don't want to work...
DFKK
Postby Adik » Wed 14. Mar 2018, 19:30
Ok,you have two soundcards,thats ok,you created output forces??you must create a force,like you created a leteral and longitual forces.for me works rpm very good.you tried this?
Adik
Postby DFKK » Tue 20. Mar 2018, 20:16
Hi! Thanks again! I load a profile that contains a lot of forces thru the math. But nothing happened. Or... when I use more than one profile it just skips to the first profile. The only way to get this profile operates is to delete all the rest and leave this one in the list. But anyway... no sign of life... Maybe some interference with other ports or oprograms that im using on my computer couse the problem so i reinstall the op system and I'll be back. :)
DFKK
