General questions on wheel+pedal building
Postby metallo97 » Fri 28. Mar 2014, 20:04
Hi all, i'm going to build a FFB steering wheel+pedals+shifter and i've got some questions i think you can reply...
So i think i will be using the MJoy16 AVR controller for the wheel, pedals and shifter. The shifter is very simple to do. Two of the three pedals would come from a crappy steering wheel, but i need to do another one...
The most difficult part is creating the steering wheel. I'm gonna use a wiper motor for the force feedback. And now begin the questions...
How do i make a simple potentiometer turn 900°+? Do i have to create some gears?
Then which is the simplest h-bridge? I have an arduino, i think i can simply attach an h-bridge shield and an external power supply and then the signal would come from the software...
Thanks all for the help!
metallo97
Re: General questions on wheel+pedal building
Postby vicpopo » Fri 28. Mar 2014, 21:11
Postby RacingMat » Fri 28. Mar 2014, 21:14
Hello metallo!
You're aiming an ambitious goal! Great!
Among the many points you listed, you will have to drive the torque, not the speed : hence Hbridge won't work! You need more elaborate drive.
Mat
Postby metallo97 » Fri 28. Mar 2014, 22:38
Thanks man! I had already seen that, so do you think it's better to go with the AS5045 for the steering wheel?
Better one or two motors? I will use a wiper motor and i think it will gave me lots of torque...
And at last, i want this to be cheap, so nothings very professional... :)
metallo97
Postby RacingMat » Fri 28. Mar 2014, 23:47
There are many multiturn pot! but quite expensive (~30€) or you can use gears to reduce the range (but you will reduce precision as well).
Prefer cermet track.
Choose linear (non log) 10k pot.
Postby metallo97 » Fri 28. Mar 2014, 23:56
Definitely the pot way it's the cheapest... I think I will search for multi turn one but they're like 10 turns which are very much for a steering wheel!
Inviato dal mio Nexus 5 utilizzando Tapatalk
metallo97
Postby metallo97 » Sun 30. Mar 2014, 01:39
Maybe the best thing is to place a magnet on the shaft of the motor and the magnet sensor directly in front of him...
metallo97
Postby RacingMat » Sun 30. Mar 2014, 12:35
But you will only get 360•
Postby metallo97 » Sun 30. Mar 2014, 12:41
Are you sure? I think that with the help of a microcontroller like an arduino, if you reach 360 degrees and it suddendly goes to 0 degrees he would think that it's another turn on the same direction... This would be even easy to program... So i would even need an arduino to control... So, instead of creating a new FFB board i can use the arduino for sending/receiving FFB commands and to send controls for the wheel axis to the MJoy...
metallo97
Postby RacingMat » Sun 30. Mar 2014, 21:08
It would be easy to program if all the values were consecutives... Your arduino will not see all the values due to refresh and calculation rates!
But it's probably doable...
