Max 68A Dual Motor Drive Module = shit !
Postby ericRacer » Tue 15. Oct 2013, 19:11
hi,
I bought this module :
http://www.ebay.com/itm/High-Current-Du ... 33806c6614
and connected it with my arduino nano exactly like this post :
http://www.x-sim.de/forum/viewtopic.php?f=39&t=723 !
and that was working fine with a very little motor but when i connected my big one with no load , it has begun to smoke !
my motor is similar to this one :
http://www.motiondynamics.com.au/worm-d ... orque.html
I think this module hasn't an overcurrent protection like my sabertooth.
I wonder if other people have got success with this driver with similar motor ? :ugeek:
ericRacer
Images: 36
Re: Max 68A Dual Motor Drive Module = shit !
Postby telfel » Tue 15. Oct 2013, 22:10
Why aren't you using the sabertooth ?
telfel
Images: 54
Been thanked: 9 times
Postby ericRacer » Tue 15. Oct 2013, 22:49
I was thinking it was stronger than my sabertooth 2x25amp but no !
ericRacer
Images: 36
Postby menix » Wed 16. Oct 2013, 04:26
The same happened to me my motors are like yours and i had this Bridge
http://www.ebay.de/itm/330854284636?ru= ... 26_rdc%3D1
menix
Postby telfel » Wed 16. Oct 2013, 14:48
Hi
I have 24v 375w wormgear motors on which I have tried various H bridge types, all have failed so far.
I am now testing the sabertooth 2x60 and the Kangaroo module, I am running with no load on the motor 4 t o 5 amp run, 12 amp on fast direction changes with no problems so far.
regards Terry
telfel
Images: 54
Postby ericRacer » Wed 16. Oct 2013, 15:42
telfel wrote:Hi
regards Terry
Hi Terry,
Do you have the link for the motors ?
How do you communicate with the sabertooth ? analogue 0 - 5volt or Packetized Serial Mode ?
I am not sure but i think the smoke arrived when i adjusted the potentiometer for having 0 RPM (trying to stop the motor via the pot) ! :shock:
Maybe the 4 Mosfets in the power stage are opened in the same time ! i don't knows :?
i am going to take back my sabertooth too, i have good result with it (2x25amp.).
https://www.youtube.com/watch?v=Jum_WTOCbkw
Eric :P
ericRacer
Images: 36
Postby ericRacer » Fri 18. Oct 2013, 19:21
telfel wrote:Hi
regards Terry
I read on the kangaroo and it seem very interesting. I hope you give us feed back about it ! :D
ericRacer
Images: 36
