PROBLEM POT!!! HELP
PROBLEM POT!!! HELP
Postby ESKUDERO88 » Fri 13. Sep 2013, 16:37
Very good people good after having my simulator stopped and turned to pick up everything and I have a problem is that the signal is not stable potentiometers I have connected to the power supply 5v e sabertooth tested using several external sources such as magazines and such but nothing impressive signal peaks paste what I have ridden with and sabertooth velleman GREETINGS!
ESKUDERO88
Re: PROBLEM POT!!! HELP
Postby RacingMat » Sat 14. Sep 2013, 09:14
Hello ESKUDERO88 !
Your pot problem can have different origins :
:arrow: poor quality : are they cermet track ? (ceramic metal) or plastic track ?
:arrow: shear forces on pot inducing jumps on the track ...
Could you send pictures of the mounting ? it will be usefull for giving you the answer
Mat
PROBLEM POT!!! HELP
Postby RacingMat » Mon 16. Sep 2013, 17:17
Hi !
Have you solved the problem ?
More hints
- Do you have tried with shielded wires ?
- Yours motors are eletrically isolated ?
Postby Tombo » Mon 16. Sep 2013, 18:49
I had the same Problem cutting down the Pot shaft and using shielded cables like telephone cable worked for me.
I connected the shield only to arduino gnd.
Tombo
Images: 36
