Thanks in anticipation. Mike
gears on a multiturn.ferslash wrote:About potentiometers:
Yesterday i had a bad day connecting my pots, i was trying a new solution dad din't work, i will use a "clasic aprouch" i just have a question, is there any know problem using slider potentiometers??? because, as far as i see, everyone use pot (the rounded ones)
best regards
fer
motiondave wrote:ferslash wrote:About potentiometers:
got a sketch of how you plan to set it up?
BobBuilt wrote:I have successfully connected a pot directly to the output of a big worm gear,
