JRK 12v12 versus other pololu boards
Re: JRK 12v12 versus other pololu boards
Postby motiondave » Thu 27. Sep 2012, 01:39
Can I please say here, that I would like to see a reasonable priced controller THAT WORKS IN X-SIM with a simple code we can use and the ability to use different h-bridges on it.
I am happy with 12v, but I would like to experiment with 24v and maybe even 240v motors at a later date.
But as I am less intelligent in code, I hope there may be a solution found for a controller.
Thanos, I have donated to the cause for a controller and I hope you can come up with something.
Otherwise, long live the JRK.
Postby Inside » Tue 2. Oct 2012, 06:20
Ok tronicgr,
I'm thinking of ordering two of the motor drive modules you suggested and also two of these -- http://www.trcelectronics.com/Meanwell/se-600-24.shtml -- one for each motor. Do you know if that motor drive board has a diode on it to prevent inductive kickback from when the motor switches direction? Do I need do add something to it, or does it just work out of the box if I connect the wires?
I'm thinking that the MPJA specs are probably wrong regarding the current draw. It makes no sense for a motor to have no-load current of 10@ 24V and then 5A @12V. I think it'd make more sense if it was 5A @ 24V and then 10A @ 12V meaning that the power is about 120W.. At least that's what I think. I can't seem to recall anything about motors anymore.. Hopefully the 600W PSUs will be enough for these motors. Does that seem right?
Inside
