engine starter as motor?
Re: engine starter as motor?
Postby speedy » Fri 30. Aug 2013, 17:37
Hi :
Rewinding a starter motor coil and reducing the wires thickness is not good for the motor performance side ... the motor characteristics : All dimensions, wire thickness, air gaps, type of mechanical gears used , etc. ... determine the torque and RPM of the motor ... Reducing or increasing in random way any of those parameters can make huge decrease the performance ...
I have tried to do so two times till now with thinner wires and more windings turns ... But the performance of the motor is dramatically reduced in both tries .
check this site http://www.reliance.com/mtr/flaclcmn.htm
regards
spe ;) edy
speedy
Has thanked: 14 times
